What is this part?
10 Nov 2016
After draining central heating when i turn the boiler on the 2amp fuse on pcb burns. If i disconenct wires from this part the boiler coms. This part is screwd on pipe giong into pump
Cheers
Artem
It is a Low water contents switch, which prevents the boiler from running if the boiler is dry or has low pressure
Did put aa screw trough heating pipe under floor frst flooe. Drained the syatem to get it fixed and when backbon straight awat 2ampbfuse is burning. The actual fart was not leaking
Thank u mate, thats what i thought
Enywhere i can buy it
I would doubt if you actually need one its just a switch and the reason the fuse doesnt blow when you disconnect it is the rest of the components dont get power its vey easy to test it but it is a boiler safety device so I cant give you any more advice on here, I would be disconnecting the pump and see if that stops the fuse failing
I am awaiting new boiler installation, on sunday. Would be nice to have at least hot water. But i am stopping messing with it. Thanks everyone for help
Cheers
Artem
