Good evening all,
I'll try to be concise as possible:
From the brilliant advice on this forum, I think the PCB on the Potty has gone (no mains lights on boiler, fuse in mains suppy ok, when I press the 2amp fuse on the PCB (with an insulated screwdriver!), the mains lights briefly flash and there are sparks behind the PCB - I only did this once).
The boiler is nearly ten years old now and I don't expect it to last much longer. For this reason, I was checking out the recon'd units on Ebay for around £30.
The PCB inside the boiler is definitely part number 21/18867 and this is for the Potterton Puma 100 (permanent pilot). However, mine is the Potterton Puma 100e (I have just gone and checked and it definitely has the electronic pilot). So according to it, the PCB is the wrong one for the boiler !
Is this common ? Did Potterton interchange the parts ? Just want to be sure before I order the new part.
Thanks all, much appreciated.....
