Hello,
I am looking at getting a good router now I have done some research into this but everyone says different things and has different opinions.
Basically I will be using the router for rounding edges, making holes wood for tea light holders, cutting edges on specific angles with chamfer bits, and routing out window frames in wood.
These are the things currently I am looking at doing with it but in the future would possibly be more. I have read that both would be ideal as some stuff would be better done in a fixed base and others in a plunge.
I know you can get ones which have interchangeable bases but I have found these are quite expensive. I have also read that plunge routers can be fixed to a Base and used as a fixed router. Is this true?
Am I correct in what I have read and if so what do people think the best approach for my router should be? plunge or fixed?
What routers would people recommend? and is it worth having both sizes of collet available on the router for the greater array of bits?
James
James
