Insulation: The R value myth
11 Feb 2016
Happened to read the following article. Would love to know what you all think about it?
The R Value Myth
In any system design you have to have some constants.. Its not unreasonable to work with norms and design around them. At a Macro level you could plot the typical conditions a house will face in a given location on a chart and most will cluster around a norm. Its therefore not unreasonable to design systems and specifications with those in mind.
The article also seems to be based around the design of American houses which are often SIPS based.
Well our architect did a condensation risk analysis for every month of the year based on internal and external temperatures and made sure there was no accumulation of moisture.
So yes if you get it wrong, all sorts can happen that you don't want, so that's why you should check first.
Moisture coming overnight and going during the day isn't a problem, it's when it hangs around and never evaporates for whatever reason.
Consider the R-value of an insulation after it has been submersed in water or with a 20 mile per hour wind blowing through it.
if my house was submerged in water, or if the walls and roof fell down leaving just the insulation exposed to the wind, R-values would be the least of my problems.
Some nutty yank with an axe to grind wrote that garbage.
Why?
Didn't they know how to design?
I've never heard such nonsnense as "Condensation risk analysis" , but the sad thing is that I'm hearing it more and more, and invariablly for the wrong reasons.
Walls that breathe can have high insulation and do not need vapour barriers.....
[B]André Bourassa said:
[/B]
I also wanted to mention that when it comes to thermal insulation, it is the thickness that counts. Thirty-five centimetres means approximately 14 inches of insulation. Wood wool gets used a lot. It still does not exist here, but there is a mill that is going to open in the National Capital Region. There is also a lot of cellulose used in insulating products that they use, but that means you end up with very, very thick walls, which needs to be factored in.
I should also stress that under the Swiss and Austrian criteria, and to a large extent in France too, those that are at the forefront of the green revolution build walls that although very thick and very well insulated, nevertheless let the humidity escape from the building, they breathe. Just like you would not go cross-country skiing in a rain jacket — there are materials like GORE-TEX, for example, that allow the body's moisture to escape when you are engaged in these activities — we want to develop a housing environment that allows moisture to escape just like a GORE-TEX coat does. And as far as that is concerned I can speak frankly when I say that in Quebec and in Canada there is still a lot to be learned.
We are behind on that score, and we are still using type 1 vapour barriers, plastic and aluminum, and there are better ways of keeping moisture levels at an appropriate level in houses. I am not saying that you can snap your fingers and change things overnight, but things are moving on that front. Back home, in our architectural practice, we have been making walls that breathe for the past 20 years. Now let us be clear, having walls breathe does not mean that they are full of holes. I am talking about walls, just like GORE-TEX, which keep you warm, but which let the humidity out. And even if your rainproof coat had air holes where your armpits are, you would still be extremely uncomfortable. The same is true in a house, it is good to have something to circulate the air, but not just to control moisture.
read a great deal more http://www.parl.gc.ca/Content/SEN/Committee/403/agri/02eva-e.htm?Language=E&Parl=40&Ses=3&comm_id=2
I think we have got to a point though where U-values are getting so low that we are introducing other problems. Personally anything with U-value sub 0.1 is a bit pointless unless you've also excluded drafts, minimised windows etc.
The person writing the initial article shows he has a little knowledge of a lot of things, and shows he doesn't understand the reasoning behind the testing procedures to determine an insulation value. In the summer when it's hot outside, it'll be immaterial which side the vapour barrier is, but in the winter, when the insulation is needed, the vapour barrier needs to be as specified in the manufacturers fitting instructions.
I suspect he was the person that overthought the problems, and put vapour barriers both sides, but won't admit that he screws up.
As to continually lowering the U-values, I've heard reports where the over insulated houses can't soak up the summer heat, and are unbearably hot.
I love that the advert appearing in this thread is for
"EcoQuilt Foil Insulation - equivalent to 120mm of fibre but only 15mm thick"
That's something you do when you've got too many programs running an need a bit of clear screen space, right?
On a serious note, it's not necessarily about minimising glazing, it's about orienting and shading it correctly so it naturally provides good solar gain in winter when e sun angle is low, and low gain in summer at higher angles. It's possible to desi windows that admit as much heat as they lose, so when it is buffered sensibly it makes no overall difference
Insulation does work both ways though.. it keeps your paid for heat in in winter and keeps the radiant heat from the sun beating on the tiles out in summer. If there's a problem with the equation it's simply that the design of the house lets the wrong amount in in the wrong context.. it's not correct to say "oh my loft conversion overheats in summer because of all the insulation", it's more a case of "my massive roof lantern in the midday summer heat is the equivalent of having a 16kw fire blazing away in my polystyrene box"
The solution is not to find a way to get rid of the heat accumulated inside, it's to keep it out in the first place..
The americans have a problem we in uk don't though. They can have air conditioning in the summer and heating in the winter. In uk the vapour barrier goes to the inside. Warm air holds more moisture so what you want to control is warm air leaking out since as it gets colder it will then condense somewhere in the wall. Or control where it condense to the outside face of the cavity. In USA, winter, heating same applies. In summer it is reversed, outside can be hotter and have more moisture so damp occurs on the outside surface of the vapour barrier.
