ive been playing wih some Fibaro dimmer modules and have noticed an odd thing; first to explain the setup:
The modules have a live and neutral connector, and a switched (dimmed) output.. They also have two terminals across which a press-to-make switch is installed. In normal wiring setup, I supply live and neutral to the dimmer, connected the output to one side of the bulb and the supply neutral to the other. The switch terminals run to a PTM switch, everything works as it should; click the switch to activate the lights, hold it to change the dimness setting etc.
the PTM switch has a metal body but testing with a multimeter shows no direct connection between the terminals and the body. The distance between the dimmer module in the ceiling and the switch is probably 10 metres
Now to the query.. Out of idle curiosity I placed a voltage detector pen near to the switch and was a little surprised to see it beep as I was under the impression it was supposed to be a volt free connection (though I have, when the dimmers are actively powering the bulbs, measured a voltage between the switch terminals. Of course, the use of a meter across them then causes the dimmer to change state, even though the internal resistance of a voltmeter is very high, it seems the dimmer can still detect it as a switch press).
What I really can't work out though, is that the pen stops beeping if I touch the body of the switch. Is there really any appreciable voltage presence? Is the pen being overly sensitive to a stray electric field that is disrupted by the introduction of my hand?
It may also be worth reporting that I've already returned one of these particular brand of pens because it beeped every time I touched it against my head, so I'm not looking to it as any reliable measure, but the replacement does at least beep consistently when touched to things that are live and not when touched to things that aren't
Ultimately I'm trying to work out if there's any shock risk to the user from interacting with a switch connected to the dimmer, and whether I need to change the metal bodied switches for plastic ones (or at least cut one open and verify the integrity of the insulation between the user and the terminals)
