- Joined
- 10 Apr 2016
- Messages
- 111
- Reaction score
- 5
- Country
Hello,
My open vented - 12 radiators - 2 floors house central heating system keep bubbling air within all the time.
I bleed air out everyday but nonetheless air keep developing in the pipes; one can hear air bubbling from ground floor pipes up to the first floor, where the pump is installed and moving around..
These bubbles are very noisy.. some time I suspect the boiler heats water too much and steam develops so much the noise is.. however I find difficult to believe this is the case..
The central heating is quite old (1990); all was ok until the plumber changed few panel radiators with new "designer" ones (these use a lot of water apparently) and changed the water cylinder as well new circulating pump installed.
I tried to eliminate some potential sources of the problem but no luck
-Checked if there are leaks by closing the water filling line; after a week the tank level still good, so no leaks
-Changed HW cylinder to rule out any leak of hot water into central heating water
-Changed circulating pump with new unit
-Checked CH electric valves; both working
I thought the issue may be in 3 new TRV valves (bulldog) that looks quite flimsy (not happy at all) but not sure this is the issue.
Any advice?
Many thanks
Any advice?
Many thanks
