- Joined
- 9 Jan 2017
- Messages
- 11
- Reaction score
- 0
- Country
First post here and I'm more use to working on aircraft than CH systems so be gentle.
Moved into a house in September and since 14th October until today I've used 1770m3 of Gas. Basically my suppliers expected quota for the year! that's 19000kwh!
It's a four bed detached whimpey home, ten years old, two of us in it, cavity wall insulated etc etc.
We run lean, I run tight. Heating is set to 19 or off.
The system comprises of the following:
- Drayton stat in hallway
- Ideal FF350 boiler sited in the integral garage.
- boilermate 2000 running the CHW
I've read the online PDF on the boilermate and spoke to the owner about operating it. His advice was to leave the boiler stat maxed out (which agrees with boilermate instructions) and frost stat turned to 10degC.
The frost stat is next to the boiler in the garage.
I turned the boiler stat from 6 down to 5 as it didn't seem to cut out at that setting. I also dropped the temp on the frost stat to 2degC as that was also bringing the boiler on early. I've fitted a room thermometer to monitor that and the garage is staying around 10degC.
The boiler was serviced by BG when I bought the house.
So my question is what should I investigate first?
I can get the actual gas meter checked but wander if it's a boilermate issue that anyone has recognised from previous experience?
My gut is telling me to turn the boiler down to 2/3 but that goes against the logic of boilermate and the heating will run for longer.
Radiators all have TRVs and they heat evenly.
