Hi all.
New Member here from Cornwall down in the South West of the UK.
At the moment I am installing a new bath which includes the waste. Now here is where I have a problem. When I put the new shiny plug hole in, there is a rubber washer that goes between the bath and silver plug hole. This washer is flat apart from the inner circle which is slightly raised all the way around.
The question is, do I place the rubber washer with the raised area facing the plug hole or the other way around.
Another question I have is that I have a tube of GP200 white trade silicon. Can I use this on either side of each washer to make a better seal or should I leave alone and just use the supplied parts.
Wish I had seen this forum before now, it might have saved me a bit of money, hassle and foul language !!.
Once again, hello to all and hope to speak to you all again soon.
Cheers
Cheers
