D
Doggit
It may not be damp on the party wall; it's possible that it's excess moisture in the room settling out on the cold spots of the dab.
Sorry, I missed this. I'm not sure if I have a breathable roof membrane, but the roof is 8/9 years old, the membrane is green. How else can I tell? The veluxs don't have trickle vents!Do you have breathable membrane on the roof?
Keep the trickles open on the Velux. It's probably more a case of insulation and a robust method of achieving a VCL.
Thanks doggit. How do I tell?It may not be damp on the party wall; it's possible that it's excess moisture in the room settling out on the cold spots of the dab.
The first click on the bar handle is a trickle vent.The veluxs don't have trickle vents!
Ah! Great.The first click on the bar handle is a trickle vent.
I see. Noseall may have saved the day with the news on the velux trickle vents. The room does get warm in summer, it's a 4 bed house. Do I have consensus that pointing, dpm painting, vcl layering, battening and boarding is the way forward? Maybe I should salt neutralise chimneys too?It's not so much how you tell, more of just determining the best way to go. If you haven't got the trickle vent open, then how are you ventilating the place. If it is excess moisture in the room, and you don't deal with it, then it'll just settle out somewhere else when you insulate the cold wall.
Thanks. And what do I do if the brick work does prove to be damp?
With regards to re-dabbing it, I was planning to batten to minimise contact between board and wall, but does most insulated plasterboard have an inbuilt DMP?
Also, what would your belt and braces suggestion be? The room will be recarpeted and decorated so belt and braces is preferred!
Thanks again
Thanks Roy CYou cant dot and dab straight on to foil back plaster board. There is no suction on it...You may be able to sbr the back and throw sand on it but I have never heard of that being done. See what the "lads" say....I stuck polystyrene onto foil back with "Unibond" years ago then dot and dabbed them onto the walls....That was before you could get poly backed plaster boards!!
