Hi All,
I have recently purchased a Nest to install alongside my combi boiler.
My boiler currently does not have a thermostat, it has a timer / controller on the boiler that I use to turn on / off the CH.
The thermostat connections on the boiler are 'volt free' and currently there is simply a loop across pins 1 and 3.
I've had a read through a number of posts and from what I have read installation seemed simple. I needed to use the low voltage nest install taking two wires from pin 1 and 3 on the boiler and running them up the the nest heat link unit on pins 2 and 3.
When I press the override on button on the nest heal link the unit just appears to attempt to fire over the relay but cant. It sits in a loop trying to fire up the boiler with the green lights going on / off on the nest unit.
The nearest thread I came across was http://www.diynot.com/diy/threads/nest-thermostat-and-baxi-combi-105e.416527/
My boiler manual states the following:
and the nest instructions state the following:
Any help would be greatly appreciated.
Many Thanks, Gavin
Many Thanks, Gavin
