- Joined
- 7 Feb 2017
- Messages
- 9
- Reaction score
- 0
- Country
Connector block, not box, i.e. a piece of 'choc'block. You can do it yourself, there should be enough room in the back box.What's the deal with a separate connector box?
They're not needed for this dimmer switch. Some dimmers use a neutral, but they aren't that common.Thanks for all the responses. Why do I need to 'park' the neutrals? Are they not needed for a dimmer switch?
And I assume L2 would be for a second light if I had one?
I found a lot more cables than I was expecting and none were wired in a way that made sense for the new switch.
DIY electrical work isn't compulsory, but if you choose to do it you should reflect on the fact that unlike dodgy decorating, where runs in paint and bubbles in wallpaper won't kill you, or dodgy carpentry, where a wonky book case won't start a fire, electricity takes no prisoners, and you really, really ought to spend some time learning how things work if you want to fiddle with them.I assume L2 would be for a second light if I had one?
