Hi all,
Hoping someone can help. I have a McDonald Engineers Thermflow Thermal Store in my house.
My water pressure has dropped, most noticeably in the showers. Now if I run another tap whilst having a shower the water coming out drops quite a lot and if the bath is to be run, literally no water will come out any of the showers. My house has 3 showers.
I recently had a new kitchen installed and had the incoming mains water supply moved. An island was installed so the mains supply was moved from the outside wall to centre of the kitchen.
The boiler was also replaced at the same time though this should have no effect on the mains pressure as it is only heating the water in the store. The only other thing that was changed again around the same time was the mixer valve for the thermal store as the old mixer had started leaking.
I'm looking for some advice on what could have caused the drop in pressure? I had the plumber back out from the company that installed the kitchen. They are saying that the repositioned incoming mains hasn't altered the water pressure. I'm not so sure on this as it was after the kitchen installation that I noticed the drop.
So any pointers on what to check would be appreciated.
The below shows the thermal store in the airing cupboard:
Cheers
Kevin
Cheers
Kevin
