Any help appreciated.
On the top of the oil control valve I have the electric component that plugs into transformer. As the temp rises, the lever above the pin (which is attached to the float in the reservoir I guess) rises. However. There is a gap between the pin and the lever. I think this is preventing it from increasing flow. Although I have to admit never checked it when it was working fine.
Should the lever be magnetic so it pulls the float up when it rises?
Symptoms are that current thermostat is on 5. Main oven only reaches around 210.
Some times when it's kicks in and send fuel on high burn it's rises to over 250 but this isn't regular, to a pattern, or predictable. So just trying to find out if it's because the lever isn't pulling the pin up to increase flow when thermostat demands.
I was led to believe that around 4 on the thermostat should achieve 240 in the middle part of the roasting oven but I've never seen it sit at that..
Thanks. novice.
Thanks. novice.
