any idea why this leaks it's a direct replacement and drops from underneath. There is a rubber o ring on copper pipe that seems in good condition, just never came across one of these before so any help appreciated regards david
lol it's slides on to easy thinking ptf tap round o ring abd try that as said never had to change one before
PTFE covered O ring
Must try that sometime
Everyday is a skool day here
I must put all those O rings I keep stocking in the skip, better to get a roll of PTFE instead. Silly me
Wrong place and wrong holealso remember grease her up as well
Why the sarcasm genuine question dp everyday is a school dayPTFE covered O ring
Cheers will check on that. That's makes a lot of sense appreciatedAs already said the o ring should be captive inside the white plastic bit, if you look inside there should be a groove that the o ring sits in.
I don't mean nod a just Kev and laugh but don't talk to me like I'm a fool plz peace
No probs late night a lot on my mind dp I must be turning into a grumpy old manSorry fella
There are times when the question and answer is so simple, but the cure is often muddled by not thinking the issue through
An O ring is a sealing medium. Why would one put PTFE tape on that?
This suggestion is very similar to people putting PTFE on a fitting thread
My apology.
Sounds like my average day!![]()
