Liquid polyeurethane
7 Feb 2010
Which is easier and more cost effective for a DIY flat roof, with an OSB deck - EPDM or liquid polyurethane? I've successfully used EPDM, but not tried the liquid system.
Cheers
Richard
Some questions
  • How many square metres do you need to cover and what are you covering (garage, extension etc...)?
  • Do you have any liquid polyurethane systems in mind?
  • Are you going over the existing surface or putting new decking down?
Some questions
Thanks for your reply. 25m2, garden building with warm roof, new deck.
No particular system in mind. I noticed Polyure in a builder's merchant's flier, then read about Elastathane. Atmospheric moisture-curing systems that you roll or brush onto the substrate, using reinforcing mesh to bridge gaps and joints.
Cheers
Richard
EPDM. Liquid systems require more than a half day training course to learn how to install them correctly. Especially fleece systems.
Liquid polyurethanes tend to come in two versions; a one pot wonder that overcoats or repairs the existing surface (These don't usually come with a guarantee) and then the full blown all singing all dancing versions that have either a fibreglass or a polyester reinforcement.
Upsides to polyurethane
  • Moisture cured so no catalyst or additives to worry about like a GRP system
  • Extremely flexible, so no problems with thermal expansion and contraction
  • Sticks to everything (including contractors)
  • Seamless finish (unlike EPDM)
Downsides to polyurethane
  • Price - depending on the system they can get pretty expensive
If you have the budget and like a system then go for it, Liquid polyurethanes are really really good. If you want a seamless liquid applied system on a smaller budget then GRP Roofing might be the better option. It's a bit more fiddly to install but it'll still give you a seamless finish and a 25 square metre roof shouldn't have any flexibility issues which is polyurethane's main feature.
It's the one-pot wonders I'm looking at, which claim to be suitable for a new deck as well as repairs to an existing surface. With reinforcing mesh to joins and gaps. I hadn't worked out the cost yet in terms of coverage (when I did a similar EPDM roof it came in about £18 per m2).
Not keen on fibreglass as I'd be against the clock and have visions of ending up with a pair of boots stuck in the middle of the roof.
At the end of the day there's no reason I can't use EPDM; just wanted to explore alternatives.
Cheers
Richard
