Have had the foundation trenches passed for my side kitchen extension by building control and have poured my concrete thus now considering myself a professional builder! All good. I intend to reuse the bricks from my exterior kitchen wall to build below DPC so they match the rest of the house (75mm imperials) as I am finding it very hard to find something similar. Above is to be rendered block. Anyhow, this means the removal of the kitchen wall and insertion of steel beams.
The opening span is 357cm so with a 10cm bearing on either side would require a 377cm beam/s. All they are to hold up is the gable end of the current single story kitchen. The outer skin obviously goes full height, but the inner skin only goes up halfway (pic). The new warm flat roof will cover the outer beam. My BCO officer suggested 2 x 6x4" beams bolted together to support both inner and outer skin of my 9" solid wall, then suggested 7" beams might be better. He agreed SE calcs are unnecessary for this support. Cost for beams is £200 - not bad.
Having bashed an exploratory hole in the old kitchen ceiling, I have come to the conclusion that to maintain the 9' roof height between old kitchen and the soon to be started new part of the kitchen, the steel beams need to sit level with the top of the wall plate on the old kitchen roof to avoid being on display in the ceiling. This presents a problem as even if I were to go for the smaller 6" beams, the top would hit the laths of the old kitchen ceiling.
Enough rambilng from me - Questions:
1. Will 2x 6x4" beams bolted together be sufficient?
2. How can I fit them in so that they sit level with the top of the original wall plate?
Help appreciated from a learn as you go have a go hero.
