Adapter for this tester?
would be 15mm pipe. Only think I can think of is a 1/4 bsp female to 15mm compression. If they do such a fitting?
Thanks for the help. guessing there's no push fit option? As would be a lot easier to re-use.
Use a YP2LC on a short piece of copper.
You can then use a pushfit or comp fitting of choice.
Can anyone confirm how to use this I hooked it up to my manometer and the pressure keep dropping. Thought there was no leak was just a full length of pipe with a cap on, was just testing the kit. This stopped when I put a spare piece of manometer hose from the open ended nipple on the manometer. That there always is on a manometer when testing. To to blank on the test kit.
My gas safe plumber I work for, doesn't test his pipework before he applies corrosion protection as he say he trusts his soldered joints. However I'd like to be sure.
I always make a tee piece up with a lever valve on it. As I never trust the hand bellows not to loose pressure back through them
