Too much heat
m0t
23 Oct 2006
Came downstairs just now and found the the heat of the sun through my French doors has heated up and buckled my karndean floor.
Can't I get something to put on the glass to stop this happening?
You can get reflective film. It might also make the glass a bit more difficult for a burglar to break. it has a slight silvery appearance.
But I would be wondering if the floor was laid correctly, with expansion caps round the edges.
I laid it myself and there are the proper expansion gaps.
The planks went completely soft and were very hot
I've not heard of that happening before - perhaps call the Mfr's tech dept. They will probably want pics, the adhesive type, and wrapping # details.
Thing is, there's more and more glass being used in residential walls (& roofs).
Sunlight on "varnish" etc. & hardwood has been a forever problem - traditionally "solved" by re-sanding and finishing.
