Well flex actually not cable
Typical .... just bought new circular saw, and after a cut, put it down and it neatly fed flex into the blade ... last saw lasted 20+ years ...arrrrgh!
This looks like standard 1mm2 - 2 core PVC insulated/pvc sheathed flex.
A new manufacturerss' flex is over £25 ....
Luckily it is screw fitted in the saw body ... I have new crimps - so that part OK ......... is this flex anything special ? printed on outer sheath is
IEMMEQU NF-USE-1176 <VDE> H05VV-F 2X1.0mm2 N/18421 TA HSING IEC 60227 LF
Looks like a normal PVC flex to me, or does this coding specify something special on thicker sheath or low temp performance.
