Hi, after lots of complaints that our shower is not powerful enough (just moved house and its a 9kw Mira Sport) I've been looking at putting in a new unit - ideally a 10.8kw Mira Sport. Just had an electrician friend round who has checked out the wiring and it's apparently 6mm and he suggests that it'll cope with 10.8kw no problem. The wiring is a mixture of being buried in plaster and running under floor boards with no insulation. So a couple of questions :-
I've seen various specs & articles suggesting that 10.8kw needs a 10mm cable - so who is correct here ?
Was the 6mm cable even providing enough power to the 9kw to run it at full strength ?
Thank you very much in advance.
