Indeed.If you put things in near-boiling water to boil them, they'll take less time than than if you put them in cold water and bring it to a boil.
I find a kettle works well for filling a pan with near-boiling water.
Been there done that experiment. At my daughter house I noted she boiled a kettle and then poured the boiling water into a pan so I asked why. She got the kettle and emptied it, then filled with cold water to the full mark, she then poured the cold water into a pan, she then refilled the kettle again spot on the full mark. Lit the gas with it full on and switched on the kettle.
In spite of kettle being 2.8 kW and gas ring rated at 5 kW the electric kettle won, and likely could have boiled a second time before the water on the gas ring boiled. I was I admit surprised at the result.
And put lots of water vapour into the air.Plus the fact that the lost heat from the gas situation is helping to heat the house in winter.
Get a dehumidifier, then you get back the heat from evaporation (plus a little electric heat.)And put lots of water vapour into the air.
In the main when too hot I just grin and bare it
The problem is that even a normal-sensible-domestic large pan, say 30-33cm diameter, overhangs the controls of the hob, assuming it isn't the only one in the world not designed by an idiot.PS love the frying pan.
Yes, me too, but the time taken to boil the kettle, although less than the time taken to boil cold water in the pan, is still longer than using an 'instantaneous' water heater.Indeed.
I presume that we're not trying to re-write the Laws of physics, so I wonder what power these 'instantaneous' heaters are?... the time taken to boil the kettle, although less than the time taken to boil cold water in the pan, is still longer than using an 'instantaneous' water heater.
The suppliers seem rather shy to state the power, just that they cost less than 3p per day, and run from a 13A plug!I wonder what power these 'instantaneous' heaters are?
