Hi Guys,
Not specifically an electrical question but.....
Does anyone have the armeg double box sinker kit and would be able to confirm the distance in mm between the two outer holes centres on the jig which is used to mark out the guide holes for the circular cutter? See below image
I recently picked up a kit off ebay but the jig is missing and I’ve not been able to find anywhere that sells the jig as a separate item.
If i can get the hole centre dimensions I can easily knock something up from a bit of scrap metal to do the job
