I've just come across a problem while digging my water meter out (we're replacing the lead main). The hole was filling up with water when i got so deep. I was sort of expecting this as the meter itself has been sat in water for over a year (we bought the house last year). Anyway I started thinking I should call the water board to inspect the pre-meter pipework before I expose it so I cant be held to blame for a leak. Then R lass went to the bog and washed her hands. Water started trickling into my hole! Bang next to the meter is a drain gulley. Which everything drains into. I realised if I crouched down at a certain angle I could see into the gulley from my hole!
The hole is perfectly round from what I can see, maybe 2-3 inch diameter and faces away from the house. So is this a back inlet gulley with no back inlet fitted?
Now I think on, it was blocked up when we moved in. It took a lot of messing to unblock it. I'm guessing soil has been washing into the gulley from this inlet, as there was a big cavity there when I removed the concrete.
If I expose the gulley is it a relatively simple job to replace with a plastic one onto the clay pipe?
I dread to think how long this has been leaking. No signs of damp inside.
