Help ID shower make/model
25 Oct 2017
Moved into a new house a few weeks ago and starting to work through some problems. Noticed some water on the ceiling below the bathroom yesterday which is most likely coming from the shower I think. Left it till today and no more water has appeared - didn’t use the shower this morning. Tried putting a few buckets down the waste and no water appeared. There is a drip every few seconds from between the knob and shower mixer body. Suspect the drip has been getting down behind the tiles.
I would like to replace the internals of the shower if possible to see if this helps. The only marking I can see is ‘N&C’.
Does anyone recognise the make/mode from the attached pictures? I’m guessing the bathroom is at least 5 years old.
Thanks,
Colin
64980536-F98F-491E-8B20-26BF28211D66.jpeg 17919B49-B0B4-4260-994D-83D982F275F4.jpeg AE93BAEC-B24D-4688-B67F-E74859504AC9.jpeg
It might be a rubinetterie , see if it has IB engraved anywhere.
Thanks for the replies. Have sent off enquiries to Nicholls & Clarke and NSS.
can you remove the handle and the outer round shroud/surround.
photos of the front & sides of actual valve body will indicate where it is possibly leaking and future spare parts.
Should be an easy fix (y)
Nicholls & Clarke Got back to me to say it is one of theirs from around 15 years ago, their Athena range at the time. Sadly no spares available as the factory has closed which made them.
The bathroom is due for replacement in the next few months anyway. Have patched up with silicon for now to contain the leak.
Thanks for the assistance. Off to start this weekends jobs of CCTV install and fence building
