Not allowed to run a 1 kw motor at 1kw you are only taking 4amps an electric kettle takes more.Bob
But when the notor is accelerating from stationary to full speed it could be taking 20 times rated load, even more in some cases.
I know one fitter who fitted 28mm pipe from the meter to the combi and 32mm near the boiler to give internal gas storage
Well you know BG it's a village fix.Bob
but modern boilers are all modulating and will be safe regardless of the inlet gas pressure
William Press.Yup I'll go with that I did a lot of work for the firm who did the mods on the cookers when we changed over long time now but in lincolnshire i think it was press or priess who got the job and if you were going to sub off them you had to go to the tech Coll to be told all about it,mind you they paid well and on time good on them my agent who delt with me was Bill hemstock great bloke
very honest.Bob
yes some can, they use a lambda sensor in the flue and adjust the gas valve accordingly, not all do but a modulating appliance is not a danger with a low inlet pressure, why can you not understand that ? Oh I forgot you know feck all about gas and combustion.Are you saying that a modern boiler can measure the pressure of the incoming gas as an analoge and then adjust the fan speed and other controls to modulate heat output. ?
If high demand drops the pressure in the mains then hazardous situations of low pressure at appliances may arise.
In many cases I don't think it's people wanting a combi, so much as the combi being a cheaper option if you have the water and gas service to make it a realistic proposition.Why anyone would want a combi unless they live in a caravan or small flat is beyond me.
As I said you do not have a clue about what you are talking about, if you did you would already know the answerYou forget incorrectly......
What happens when the fan is at minimum speed and the gas valve is fully open and the lamda sensor (*) is still indicating excessive oxygen in the flue gases ?. Sensoble thing would be to shut the boiler down to avoid unstable combustion and/or repeatative flame out and re-starts. In which case how would the control system know when the inlet pressure was high enough to re-start.
(*) Assuming the lamda sensor is measuring ratio of oxygen to combustion products.
