Apologies, title should have read "Vented ...."
Hi, we're intending to eventually install a unvented hot water system to run one or more showers directly. The current shower is a pathetic electric 9kw which we both hate with a passion as the flow & heat is no good and our previous property was fed via a combi boiler.
However, we cant install a unvented hot water system for a year or two whilst we carry out other works (and save up !!) so we want a quick fix. We also now have a system boiler.
So, how does this sound ? :-
In our en-suite we have room in one corner to install a new tray / cubicle, hot & cold piping already exists nearby. Our mains pressure is pretty good apparently so can we not simply run the hot & cold water supply directly to a thermostatic mixer in this new cubicle ?. Remember this is not permanent but could give us a much better shower for the period that we need it ?
Thank you.
Thank you.
