And still you fail to understand. Rewiring the internals of the motor does not alter the characteristics of any specific supply - but it DOES alter the characteristics of supplies the motor is designed/able to run from.because how you wire a motor - to which ends of which windings you connect which wires from your supply does nothing to change the voltage of the supply. To be sure you may change the voltage seen across each winding by having them in series, but to my mind the operating voltage of the motor has not changed - it is still connected to a, e.g., 400V 3-phase supply.
Let me give you a nice simple analogy, perhaps that might help you see the gap in your understanding.
Lets say you have two incandescent light bulbs rated at 120V 50W, wire them in series, and lets say all this is inside a box* with two terminals on the outside - which you connect to a 240V supply. With me so far ? Would you now agree that the "box" is now effectively a 240V light rated at 100W ? So it's designed operating voltage is 240V ?
Would you also agree that if you connect it to a 120V supply then it won't give a very good light output ?
Now disconnect the box from the supply, open it up, and re-wire the lamps in parallel, and close it up again. Is it still a 240V ? Will it still work on a 240V supply ? No, I think we'd both agree that it's now a 120V light and connecting it to 240V would rapidly let the magic smoke out.
Now, can you see the analogy of how a 3 phase motor designed for 415 V would also be either 680V OR 230V if it's internals were re-connected ? As far as I can make out, your argument is that if you take a 415V (delta) motor and reconnect it in star - then it'll still "operate" at 415V because the supply hasn't changed.
The point is that it won't "operate" off 415V (at least, not for long) - but it would now operate off 230V perfectly satisfactorily, something it wouldn't have done while configured for 415V. Moreover, the new designed operating voltage is 230V. So even if there were no 230V 3 phase supplies used anywhere in the world, there could well be 230V 3 phase motors available simply because there isn't inherently any such thing as a single voltage 3 phase motor**.
Though looking back I do wonder if you had in mind a different idea of what "operating voltage" means ?
Oxford English : The voltage at which an electrical component or device is designed to operate or at which it normally operates.
OpenEI : The voltage level by which an electrical system is designated and to which certain operating characteristics of the system are related; also, the effective (root-mean-square) potential difference between any two conductors or between a conductor and the ground. The actual voltage of the circuit may vary somewhat above or below this value.
* And before you start getting pedantic, yes lets ensure there's a hole or window in the box to let the light out
** At least as long as we're talking about "commodity" induction motors.
And since you complained about the thread having gone off on a tangent without answering any of the questions you asked, lets look back through the thread :
Where in the world do they have 230V 3-phase supplies, such that there would be motors made for it?
That's a single-phase voltage of 133V - I've never heard of a country with that.
OK, this one is pointing out that the motors do exist regardless of whether you think they should.
I'd imaging the OP doesn't really care where.
The point is that 230/400 motors are available and 230-3phase can be generated by an inverter
I think the US has something like that, 220 or so as 3 phase, 110 single.
Confirmation that lots of motors are 230/415 dual voltage, and another statement of where you'll find such a supply
Most small industrial motors are usually wound for 230 delta, 400 star.
Japan use 200V 3 phase, either 50 or 60Hz, depending on which part of the country you're in. Must use a lot of copper...
Currently working on a project destined for use in both Japan and USA, and have managed to buy a three phase motor wound such that it will work on all voltages and frequencies, connected in delta in Japan and star in USA.
At which point you show that you still don't believe what people are telling you - it's the only inference from such a question.
Were they only ever made after inverters which produce 230V 3-phase came into being?
Some parts of Europe apparently: http://www.theiet.org/forums/forum/messageview.cfm?catid=205&threadid=88103
Also explains why double pole MCBs are rather more common there.
So having been told that such supplies are in fact available, you now move the goalposts because you can't see why anyone would bother.
I'm not in the motor manufacturing business, but I can assume that those that are are making suitable motors because there is a market for them. And they certainly are not purely of use in the "magic box for single phase supplies" era.Sorry, but what that thread tells me is that 133/230 is very rare and getting rarer. I cannot see how there would ever have been a big enough market for 230V 3P motors for manufacturers to bother, or if they once did, why they are still.
In the US there is apparently a few different 3 phase ratings, but 230ish seems to be quite common. I’d imagine that would be a big enough market for them. Particularly as they are for the smaller stuff.
So here we come to the "I've never seen it, so it doesn't exist" attitude I mentioned earlier. By this point you have been told that such motors do exist and did exist before the "magic boxes", AND such supplies are still in use even if they are less common than they used to be.I'm sure they could.
I was (and still am) surprised to find that 133/230V is widespread enough worldwide for motors to have been made for it, and then later single to 3-phase converters made to mimic it. In all my years of specifying cables, PDUs, power supplies etc for IT equipment for installation in all sorts of countries it was not a voltage I ever came across.
But you seem unable to accept that :
And it still does not address my struggle about how many people, and where, could take a 3-phase motor designed for a P-P voltage of 230 and successfully connect it to a public 3-phase supply.
So you've asked a question and had it answered; asked a different version of it and had it answered; had things explained to you so that you could understand why "230V 3 phase supply" isn't the only market for a 230V/415V 3 phase motor; had your misunderstandings of 3 phase electricity corrected; and yet still everyone else is in the wrong
