Electromax efficiency question
3 Jan 2018
Hi all,
I own an electromax electric boiler.
According to its datasheet which can be found here:
https://www.heatraesadia.com/-/medi...atraesadia_datasheet_electromax_lr_output.pdf
It has "99.8% boiler efficiency and integrated economy controller"
However further down, in the same document there is:
Seasonal space heating energy efficiency class D
Seasonal space heating energy efficiency (%) 37
My question is, out of every 1 kwh input, how much heating (in kwh) is produced ?
Thanks.
With regards to heating, electricity is generally considered to be 100% efficient, you put in 1kW of electricity and you get 1kW of heat out. I guess the 99.8% is less 0.2% that isn't converted into heat and is instead used by the controls to operate the system.
Thanks Stem,
What is "Seasonal space heating energy efficiency" ? and why is rated D if it is 99.8% efficient ?
Because it's electric.
I suspect, but do not know, that the 37% efficiency is related to the hypothetical typical efficiency of the (gas-powered) power station providing the electricity. So it's in some sense comparable with the efficiency of burning the gas yourself in a gas boiler to make heat directly.
You didn't ask that ;)
To be honest I thought you would ask that, and I would want to know, but unfortunately I can't tell you.
That appears to be correct. The rather opaque calculations assume that the electricity generation is 40% efficient, and combined with other factors, we get to 37%.
Although a modern combined cycle gas fired power station is significantly more efficient than that.
