Hi, have installed the DT92E and it's working (sigh of relief) but will have to get my grandson over and tidy up the wiring as the airing cupboard is a bit of mess if I am honest. I hadn't noticed until mentioned earlier that the cable clamp hadn't been used due to my installing the junction box upside down.
I have set the Cr value to 3, I think this is the TPi value Dan mentioned as there isn't a specific TPi setting that I can see. I have also set the ECO value.
Only issue so far is that since I got it working around 11:30 this morning the green LED on the receiver has 3 times gone out indicating the relay isn't working. Is there a setting I need to adjust to stop this or is this a peculiarity of the system being wireless.
I haven't manually carried out a binding procedure as the two components came togethger in one box and if I read it correctly are already setup together.
