- Joined
- 8 May 2017
- Messages
- 10,554
- Reaction score
- 2,819
- Country
What you heard was water runningYeah mate, I done that using the isolator valves and the pressure was pretty much the same in the morning, when I opened the valves I heard the water rush back into the system and the pressure went to near zero. I’ve ripped up a section of laminate already where new radiators were fitted and there is no leaks there. I worried I need to rip up a hell of a lot of flooring etc to find this leak, if I do find it
OUT the boiler ,into the pipework .you have a leak on the pipework. If leak was on rad or the small lengths of pipe that are visible ,you would surely see it. Are pipes copper or plastic ?
