I have a steamed up double glazed unit in an externally beaded UPVC frame. Originally fitted around year 2000 by a local company who are now bust. I expected to remove the internal rubber seal, thus allowing the DGU to be pushed inwards, thus taking the pressure off the external beading, thus allowing external bead removal. However, after a bit of poking around with a small screwdriver, it seems my internal seal isn't rubber, but is perhaps a double sided sticky foam tape? The external seal does seem like it's rubber, but doesn't want to slide out.
How do I proceed - pry off the external beading then cut around the internal tape? Or try harder to remove the external rubber first? And how do I measure the thickness of the existing foam tape?
Thanks in advance
Ps this is a different house to a similar question I asked a while ago.
Thanks in advance
