- Joined
- 3 Jan 2018
- Messages
- 150
- Reaction score
- 4
- Country
Hi Guys,
I replaced my immersion element as it was very old with a Tesla Titanium Immersion Heater Element 27" from screwfix in February.
It is connected to a timer whereby we tend to just use 1hr or 2hr boost when needed, no other time.
Today the water wasn't heating so I had a look at the timer and it kept instantly breaking the output LED and found this:
Timer fuse was OK and breaker had not flipped. Any idea why this would have happened? It did have the cover on, although insulation tight up against the side but not covering it.
It looks almost corroded under the cap in only 4 months. Is this something that merits a replacement by screwfix? I can't see what I could have done to cause this. Could there be a slight leak when hot and under pressure causing the rust? Thermostat was set to 60c.
Any help much appreciated.
