How am I supposed to turn this toilet full valve washer?
22 Jun 2018
I'm trying to replace the full valve on my Ideal Standard toilet
I've unscrewed the screw connecting the pipe, but the plastic screw washer holding the valve in place is recessed in a small hole, with very little space, in an already hard to access blind back of the toilet...
How the hell am I supposed to unscrew that?!
that's the underneath, looking up?
How does it look on the inside, looking down?
It might be necessary to remove the cistern :(
Take the cistern off by removing the wingnuts on the other fixing you can see in the picture.
Can you turn the body of the Fill Valve inside the cistern - maybe wedging a screwdriver in the recess underneath, outside the cistern . Then get a tap backnut ( smaller hex but same size washer ) and a box spanner to tighten backnut on the new Fill Valve - get one with a brass shank. I don't like splitting cistern/pans unless absolutely necessary.
Welcome to the world of plumbing. If the manufacturers haven't made your life as difficult as possible, the person who installed whatever it was or the last plumber to have touched it will have. Everything you touch is either seized, rusted, broken, bodged, inaccessible - or weeps when you put it back together. A simple one hour job turns into a 'mare of several other jobs that take a lot longer. Some jobs seem to have a knack of fighting you all the way.
Every job's a b**tard in plumbing. (y)
https://goo.gl/images/7XNZhb
How Very True !!!
Not quite every one ;) Back in the day I had an old lady customer who's loft CWS was leaking round a tank connector where it had distorted the cistern slightly. I started by telling her it would be a "difficult" ie. ******* job to get it out through the traphatch and then renew it ( pre Bylaw 30 etc ) But I had an idea :idea: I could try a push fit plastic tank connector which had a larger hole thru' the cistern wall - worth a try ? Drained down one afternoon - returned next day and went for it - worked a treat, came away in plastic and converted to the existing copper - did some lagging and job was a good 'un. She was well pleased. That's how I worked for people in the village where I lived then ;). Noticed some months ago that my guttering job from '73 in same village had been changed o_O maybe they didn't like the grey Osma . Another more recent (15+ years ) for a friend involved a CWS that was high up on a stillage. Nightmare to get up to - then I found an old ali ladder which I cut to length and fixed permanently in the roof ;)
