Help with upgrading Boiler thermostat
7 Nov 2018
Hi guys, I've got a vaillant turbomax 828 and the hallway thermostat is a simple two wire affair dial type (VRT 15)
Could a thermostat with the wiring shown be compatible?
that wiring diagram is for a programmable room thermostat , not a straight swap for a simple thermostat which is what you have , you can fit one but will need rewiring
Thanks buddy, I thought as much. I'm just having a look at wiring diagrams to sort it all out.
The connections on the 828 are as shown.
For some reason we don't have the jumper between 3/4 anyway, I can wire a permanent L/N easily enough but it's the call to heat. I'm assuming the stat would be the 3&4 connectors where the stat is an optional jumper. 3/4 is joined to complete the circuit and engage heat?
So connectors 1/2 on my stat (which gives 240v when activated) should be connected to 3/4 on the boiler?
Thanks for the info guys, us Dryliners are a thick bunch lol
The LNE to your new stat should come from the same fused spur that already feeds your boiler and 1&2 from your programmable stat to 3&4 on your boiler
That's what I thought buddy, the only thing that made me scratch my head is that when the call for heat from the old stat is made there is no voltage showing between 3/4 but when heat is called continuity is made.
I didn't want to wire 240 load through 3/4 on the boiler and fry the board.
So permanent fused L/N from the spur to the stat and 'Load (1+2)' from the stat to 3/4 on the boiler, seems simple enough.
Oh, and for some reason? There is a switched live running with the stat wires, not connected to anything and left open (not protected) and that wire ranges from 30v to 240v when call for heat is made.
All sorted guys, only had to setup LN and only had to connect 1 from the stat to 4 on the boiler.
Job done
