Hi. I am hoping that someone can clarify a few things for me on my HW/CH system in the house I have recently moved into. I would like to fit a Hive Active Heating system – my current programmer is a Potterton EP3002 which has no independent settings for hot water and central heating.
I have a Worcester Bosch 40CDi combi boiler on the ground floor in a cloaks room, a Megaflow CL250HE hot water tank in the airing cupboard upstairs, a Potterton EP3002 programmer on the ground floor in the utility room and of course a room thermostat in the main entrance hall. The 3A fused power switch is located in the cloaks room next to the boiler.
I have what I assume is a S-Plan wiring system in a Danfoss Wiring Centre next to the boiler into which goes the connections from 2 x 2-port valves (HW & CH), cylinder stat, and pump (
). I can also see 4 x cables coming into the wiring centre from under the floor, and am currently trying to work out what these 4 cables are connected to.
Presumably one is for mains power from switch downstairs (
), one from downstairs room stat (
) and one from EP3002 programmer (
). I am not sure what 4th cable is from! It isn’t from boiler as that is connected to downstairs switch (white cable in switch image).
Regardless of this I assume that the change over to the Hive is pretty straightforward but I just wanted to check first to confirm the connections.
1. Existing Programmer (EP3002; see image above) has connections to L (orange), N (blue), E, 3 (HW ON? grey), 4 (CH ON? brown) – I cannot find any instructions online for this programmer but assume from what I have found on here that 3 is for HW and 4 for CH? There is also a link from L to terminal 5 with a brown wire – which I think is not required in Hive and so can be removed. Is this correct? Otherwise connections are just a straight swap – N, L, 3 (HW ON), 4 (CH (ON)?
2. I assume that as the Hive is controlled by a wireless room stat I need to disconnect the old one, which means tracing it somehow back to the wiring centre and then disconnecting the cable and putting a wired link between where the room stats live and switched live were connected. Is that correct?
Thanks for any help in confirming this before I go ahead with it.
). I can also see 4 x cables coming into the wiring centre from under the floor, and am currently trying to work out what these 4 cables are connected to. Presumably one is for mains power from switch downstairs (
). I am not sure what 4th cable is from! It isn’t from boiler as that is connected to downstairs switch (white cable in switch image). Regardless of this I assume that the change over to the Hive is pretty straightforward but I just wanted to check first to confirm the connections.
