Hi folks
I've read the other threads about insulating a condensate pipe that runs outside, and opinions seem to vary between 'it won't freeze' to 'use a trace heating'.
Last two winters, the condensate appeared not to freeze, ie no problems with the boiler. But the foam insulation has worn away almost to nothing in places. (Climaflex website does say "It can also be used externally, although it will degrade faster than normal in sunlight")
What do you think? Do I need to insulate the pipe? If so, is Armaflex more resilient? And what thickness wall do you recommend (it seems to be in 9mm, 19mm and 25mm)?
Over a 4m run, the 22mm condensate pipe drops about 300mm, then drops vertically to a drain for the last 1.2m.
Mary
Mary
