- Joined
- 13 Mar 2016
- Messages
- 29
- Reaction score
- 1
- Country
Hi all,
Perfect timing as ever, the heating is kabluey but I think with some advice I can bodge it into working until I can get an engineer out after Christmas. In a nutshell, what I want to do is stop the boiler from heating the water in the hot water tank while the tank is calling for hot water.
Gravity-fed gas hot water and central heating. The hot water side is working fine, the heating is not. When it started playing up I could get the heating to click on by flipping the switches on the controller a few times. Today it won't come on at all.
I thought it must be the controller but I removed and tested it and seems to be working fine. I also tested the stat and it too works ok. No loose wires, end of my understanding.
However, if I switch the motorised valve to manual then water gets sent to the radiators as well as the water tank. Snag being that once the tank is up to temperature the system shuts off again. If I could shut off the heating water circulation to the tank that would stop it getting up to temperature and keep the heating on. I could then regulate the temperature of the house with the stat on the boiler!
Yeah, I know it's a bodge but it's very unlikely I'll be able to get an engineer out until after Christmas. I left a message on the answerphones of three engineers today and none of them have even called me back.
Would this work? If so, how do I shut of the water heating the tank? I've been looking for a diagram explaining what the valves do etc but I can't find one.
Thank you in advance for any help :0)
Colin.
Colin.
