I'm at the tail end of redecorating my flat, and I have replaced most of the wall plates for power and light switching to new MK Logic plus stuff. The metal wall boxes for the power outlets were fine, but I have noticed that the light switch plates use an old (British Standard?) metal wall box, which seems to have had a larger gauge fixing screw ( the two that secure the face plate to the metal wall box).
The ones that came with the new light switch plates are too small a gauge, and will therefore not secure the wall plate to the wall.
The building is mid-1960s, and the metal wall boxes are original (I did not replace these, as they are firmly anchored to the original metal conduit, and the electrics megatested ok). Unlike the modern ones with a metal piece that takes the wall plate screw, these have a plastic piece that does that job, and the screw was larger. The wall boxes are in fine condition.
Is there a modern equivalent to these screws which are readily available. Seems a shame to put back the old screws, and I may have lost a couple. I would say they are 0.5 gauge or so larger than the modern ones supplied (but likely an old imperial size).
Thanks in advance.
Thanks in advance.
