The main switch has gone on my electric lawn mower. It was fine a few weeks ago. Pretty sure it's just dirty or corroded contacts. Rather than buy a complete new switch assembly, is there a contact cleaner that's safe/effective for mains contacts?
however thermal plastics melted with old switch cleaner
Been there too, the only thing is 2 identical bits of kit (which were supplied at the same time and only a few serial numbers different) were 'serviced' at the same time. One was successfully cleaned with spray, the other resulted in lots of bits of metal laying in a puddle of goo.Thanks for reviving memories of a horrific experience, the lad meant well but replacing 64 closely packed soggy plastic switches soldered onto PCB was a hell of a task.
In the early 60s I regularly popped into my local Boots and bought carbon tet in 2litre bottles. Imagine them selling it to 16 year-olds these daysI think we have all been there. That was why I stopped using it, not sure if allowed anyway today, at one point it was used in fire extinguishers but coloured red, even came is spray cans to wash brake drums rather than blow off, but not seen carbontec for years?
Same here. It was also freely available as "Thawpit", a popular and widely-used domestic stain remover. I suppose it is probably still available, in a very restricted fashion, to the likes of chemical laboratories (and maybe for some industrial processes), but it is to-all-intents-and-purposes no longer available. It certainly ceased to be used as a refrigerant, in fire extinguishers and as a cleaning agent/solvent a very long time ago.In the early 60s I regularly popped into my local Boots and bought carbon tet in 2litre bottles. Imagine them selling it to 16 year-olds these days
That's true, and, more generally, I think that the same is also true of most/all of the halomethanes etc. that used to be used as refrigerants etc. Mind you, carbon tetrachloride is so potentially toxic itself that I'm not sure that its ability to turn into phosgene at high temperatures necessarily makes things much worse!I think one of the problems with it being used in fire extinguishers was that when put onto flames it converted into phosgene. I certainly found the products of combustion very unpleasant when I poured some onto a small fire I started inside my dad's shed !!! - but it snuffed the flames.
Most switch contacts have a thin coating of arc resistant material and when that coating has gone the underlying base metal which is not arc resistance rapidly oxidises and thus a poor contact results
If the contact are just dirty then cleaning with a dry cloth may give a new, possibly long, lease of life to the switch.
If the contacts are corroded then cleaning may give a new but short lease of life to the switch as the contact material is like to have been corroded away,
Yep, but in the early 60s as an apprentice we not only used carbontet' but also benzene as instrument cleaners and it was sloshed around like there was no tomorrow. And that was at a government 'establishment'That's true, and, more generally, I think that the same is also true of most/all of the halomethanes etc. that used to be used as refrigerants etc. Mind you, carbon tetrachloride is so potentially toxic itself that I'm not sure that its ability to turn into phosgene at high temperatures necessarily makes things much worse!
Sure, but there are countless examples of situations in which, in the past, we happily exposed ourselves to (often very) hazardous things simply because we were unaware of the hazards.Yep, but in the early 60s as an apprentice we not only used carbontet' but also benzene as instrument cleaners and it was sloshed around like there was no tomorrow. And that was at a government 'establishment'
