I had to drain my Central Heating system down to remove radiators/decorate etc. Unfortunately it has been drained down for far longer than expected due to certain delays, 12 months now.
I plan to flush each radiator manually before refilling, but should I be concerned about the rust that and sludge that will have accumulated in the radiators and pipework even after flushing through?
The system is a gravity fed system with open tanks in the loft and a modern-ish (2009) Glowworm heat only boiler. It does not have a filter on it.
I am worried about powering up the system again and the pumping lots of crap round the system and maybe damaging the heat exchanger.
Should I be concerned? What steps, if any, should I take to mitigate any issues?
