E
EddieM
Tetrachloromethane, to give it its modern name, is very much best avoided. Very nasty stuff.
Indeed, but that 'avoiding' is not too difficult - since, as I wrote ...Tetrachloromethane, to give it its modern name, is very much best avoided. Very nasty stuff.
.... but it is to-all-intents-and-purposes no longer available.
Thanks for all the replies.
The problem is the switch is the kind that was never intended to be opened up and would be annihilated in the attempt. So realistically I won't know what's actually happened inside and it's certainly not practical to wipe the contacts.
Maybe I'll try a quick squirt of the specialist WD40 stuff, but more likely I'll just have to treat the whole assembly as a service part. Maybe I won't even bother with the good-money-after-bad thing with the WD40.
Thawpit and Dabitoff were carbontetrachloride, 'carbontet' was usually carbontetramethane - details may not be accurate but hopefully close.Same here. It was also freely available as "Thawpit", a popular and widely-used domestic stain remover. I suppose it is probably still available, in a very restricted fashion, to the likes of chemical laboratories (and maybe for some industrial processes), but it is to-all-intents-and-purposes no longer available. It certainly ceased to be used as a refrigerant, in fire extinguishers and as a cleaning agent/solvent a very long time ago.
WD40 is not a contact cleaner, so not suitable. It is Water Displacement version 40.
Carbon tetrachloride and tetrachloromethane are two names for the same thing, the latter being the more commonly used name these days.Thawpit and Dabitoff were carbontetrachloride, 'carbontet' was usually carbontetramethane - details may not be accurate but hopefully close.
There you go, I'm not a chemist so can only go by what written on the label and it is many years since I've handled any and been able to read the labelCarbon tetrachloride and tetrachloromethane are two names for the same thing, the latter being the more commonly used name these days.
"Carbontetramethane" really makes no sense, since methane (CH4) is already 'carbon tetrahydride', so the extra 'carbon' is redundant - and, in any event, all of these solvents were chlorinated (or, at least, halogenated), which "carbontetramethane" would not be.
Fair enough (and I'm no chemist, either!) - I suspect that you may be 'mis-remembering' a label which said "tetrachloromethane" - which, as I said, is another name for carbon tetrachloride. However, 'mis-remembering' is something I am only too familiar with (increasingly so with increasing age!), so I would never think badly of anyone for thatThere you go, I'm not a chemist so can only go by what written on the label and it is many years since I've handled any and been able to read the label![]()
Misremembering what?Fair enough (and I'm no chemist, either!) - I suspect that you may be 'mis-remembering' a label which said "tetrachloromethane" - which, as I said, is another name for carbon tetrachloride. However, 'mis-remembering' is something I am only too familiar with (increasingly so with increasing age!), so I would never think badly of anyone for that
WD40 make more than one productWD40 is not a contact cleaner, so not suitable. It is Water Displacement version 40.
Thanks - that rings some very dusty decades-old bells!Indeed carbon tetramethane would be an isomer of pentane (neopentane) or more correctly 2,2 dimethylpropane.
