Dishwasher keeps losing power
26 Jul 2015
Got a brand new integrated Bosch 4 series that lost power, called Bosch out and this was due to wiring, I found this strange, rewired the flex plate and it worked.
It's just happened again mid cycle, dead power gone.
Anyone seen this before?
Wiring of what? Do you mean the socket or FCU that supplies the appliance?
Can you plug it into another socket on another circuit as a test.
Assume it is nor mcb or rcd
Blup
Sorry not the full story being given here!
I removed the original plug to wire into a flex socket, this is then fused.
It wouldn't fit in with a plug on.
Where is the plate switched from? has it been turned off by accident [seen it happen many times] what size fuse is fitted?
Plot thickens.....when turning on at fuse spur it beeps once indicating power getting to it.
It may be that you have a loose connection at the start of the cable that supplies the fused spur & the supply to the spur is breaking down when load is applied to it. You really need to be able to test if you are loosing the live or neutral supply to the spur as the beep noise may not indicate that you have a constant supply. If the Bosch engineer has established that the supply to the appliance is not there then you need an electrician to confirm it & rectify that fault.
I'm wondering if this is where i've taken the factory plug off and its as you say gradually loosening after a while in the flex plate.
I might stick a plug back on it.
LOL went to take it out....lights on the front of it are on GRRR.
I've got my sparks coming round for something else today so will ask him what i should be doing and to test it.
