Combi boiler vibrates when water turns off
9 Jun 2019
I had my boiler serviced last month and he made a tweek to make it burn better. Since the service if the hot water tap is turned on and off before the boiler ignites we get 3 loud vibrating noises from the boiler, any idea what this is? Other than this it runs fine
Yes, just before the boiler kicks in, it only happens as my wife had the habit of quickly washing her hands when she does anything and I have noticed it is before the boiler fires up, if the hot water is on long enough for the water to fire up then there are no vibrations on the boiler
sounds like water hammer mate, I know she will never listen , but if you need HW run the HW dont turn the HW tap on for 10 secs then back off, you will never get hot water, use the cold, the boiler will thank you for it
Water hammer was what I was also thinking, just strange how we have got this issue since the service unless he has changed the flow rate
possibly that during the service he turned off the inlet water valve, different boilers use different valves, and on opening it back up again it is now at a different setting
On a combi service what would require you to turn off the cold water inlet? What boiler are we discussing OP?
