Hi all, I have an ideal Mini C24 HE that has had a problem with the pressure switch,
I thought it would make sense to get it serviced while it is apart and also replace a leaky filler loop while they are there.
The quote for the service and filler loop with part included is £125 (it doesnt required the system to be drained to change it)
He will fit a pressure switch that I will supply for an extra £25 labour so £150 altogether.
Can someone in the trade please let me know if this quote sounds reasonable? From the schematics it looks like the switch is only held on by 2 screws and a push fit pipe so the additional amount seems a little excessive?
Thank you.
Thank you.
