    Dismiss Notice
Worcester Bosch 28i Junior banging/kettling on heating only
Discussion in 'Plumbing and Central Heating' started by jsl123, 28 Apr 2011.
  1. jsl123
    jsl123
    28 Apr 2011
    3
    Thanks Received:
    Yorkshire
    Country:
    Hi, my boiler is about 7 years old and when the heating is on (DHW is fine no noises, etc) I get a kettling noise which occasionally becomes louder like pop corn with the occasional louder banging. This started about 2 years ago and has steadily got worse although during that period it can stop completely for months/weeks at a time. In addition it used to be that quite often once the noise starts, turning the thermostat down on the boiler and back up to temporarily switch off the ignition cures it for that period of heating.
    The output pipe quickly becomes so hot it is impossible to touch whereas the input remains relatively cool for a while. I live in harrogate so don't think it is a scale problem, and guessing pump related. Any ideas?
    For history about 6 months ago I had to repressurise the expansion tank which I worked out was low due to the idle water pressure repeatedly dropping slowly and realised it was over expanding and venting because of this. Inititally thought it was either a leaky radiator or valve on the filler loop which i'd mistakenly left connected.
    Any suggestions before calling an engineer round
  2. Sponsored Links
  3. Al-Glasgow
    Al-Glasgow
    30 Jan 2006
    436
    Thanks Received:
    15
    Glasgow
    Country:
    Has it been serviced over the 7 years ?
  4. jsl123
    jsl123
    28 Apr 2011
    3
    Thanks Received:
    Yorkshire
    Country:
    Sorry forgot to add that, yes it has been serviced about once every 18mths on average. Was serviced/checked 12months ago but of course behaved itself when the engineer was here :( and my descriptions of the problem didn't seem to bring any look of worry at the time.
  5. bellairaphon
    bellairaphon
    25 Jun 2008
    1,037
    Thanks Received:
    130
    Yorkshire
    Country:
    pump. u can swap the head but sometimes u get a small leak changing the pump block requires loosening a nut inside the combustion chamber. a good repair engineer should have it swapped in half hour. but u could just swap the head see how u get on.
    Nath
    • Thanks Thanks x 1
  6. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    How long does it take to do the service? Do they actually strip the boiler?
  7. jsl123
    jsl123
    28 Apr 2011
    3
    Thanks Received:
    Yorkshire
    Country:
    Less than an hour from memory. They remove the case, access the burners, etc but not stripping it down to the heat exchangers, say.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
