Hello people.
I've been given an old 200L compressor, with 2stage ABAC B70(B60?) air pump.
Its been sat for a while, fins are dirty, no intake air filter box, but other than that it got all the bits attached. Except motor, left it where it was stored as it weighed 3/4 of the compressor+tank itself. Some bright spark attached 15kW 3ph motor to it...yeesh...
Compressor shaft turns freely, compressor breathes when done so.
Its grimy to the point i will need to repaint it. Never done something like this before.
Planning to strip it down completely, strip paint off the tank, repaint, get new or clean existing fittings, wash the tank itself, fit 1ph pressure switch, gauges and motor, etc... full rebuild...
Questions:
1. Compressor shaft pulley. Any advice on how to pull it off without gear puller ? Dont have one. Its fixed by a bolt in the shaft, but i cannot pull it off after removing said bolt. No key in the shaft.
2. Stripping the tank. Is it safe to just wirewheel the whole thing ? What to do after to prevent surface rust until i paint it ? At the moment its sat outside, covered from rain, etc.
3. Painting. I plan on brush painting it. Recommend good (cheap'ish) durable paints that would be suitable for the job. Any other prep ?
4. Cleaning compressor block. Aluminium fins, some oxidation, very tight squeeze between, how to well clean that ? Not looking for harley davidson shine, but clean is good. Maybe will spray it with something to prevent further oxidation (silver paint?).
5. Cleaning brass safety valves ? Dunk em in kerosene and brush grime off ? Or is it absolutely neccessary to replace them ?
6. Motor/pulley. I have a new 1.1kW 1ph motor, 2700rpm. No idea what is rated rpm of the pump, cant find any technical info on it and not knowing that i cant buy a motor side pulley. Anyone got B60-B70 service manual ?
The rest is mostly just changing oil and gaskets, wiring pressure switch. Oil is simple, gaskets are super-expensive, so i'll just cut them myself on my laser cutter.
By the way, service kit for B60 is about 400 quid...what ?
Should be a brilliant compressor when i'm finished (unless i cock something up badly...)
Any advice on any part of this post is much appreciated. I really want a big compressor, after owning 25l whiny/super-loud/useless/cheap pos one...
Cheers
Questions:
Cheers
