New home - totally confused by system.
21 Sep 2007
Moved house and totally lost to on our heating/HW system.
There is a sealed system boiler (potterton promax SL) and 2 unvented 120l water cylinders.
5 bedroom, 3 floor house. 3 shower rooms.
Unsure if the cylinders are linked or work separate.
Also noticed pump is always running
Its a bit of a jumble. Difficult to work out what's doing what without being there. Your best bet, in my opinion, would be to pay a heating engineer an hours money to assess the system and talk you through it. That should also highlight whether there is a problem with the pump. It would be a good idea to get all the valves and controls labelled up to avoid the need for faffing about when something does need repairing.
Its a bit of a jumble. Difficult to work out what's doing what without being there. Your best bet, in my opinion, would be to pay a heating engineer an hours money to assess the system and talk you through it. That should also highlight whether there is a problem with the pump. It would be a good idea to get all the valves and controlled labelled up to avoid the need for faffing about when something does need repairing.
+1
The Tundish in your 3rd pic looks like it has been getting water backing up, you should check it out
Got an engineer coming Monday to service boiler and the 2 cylinders.
Figured the pump is always running when HW is on even when the boiler isn't heating HW.
Do the cylinders work in tandom draining together or separately?
