New glass units movement in frame
13 Apr 2019
Hi all,
Just recently had new double glazed units installed into existing conservatory frames.
Look great and I was happy with the job, but went to clean them and the double glazed units have move side to side as if either the glass isn't big enough or not been held in properly?
Is it normal to leave some movement in the glazed units? I would guess they have 5 to 10mm of movement left to right as you look at them from inside?
Hi all,
Is it upvc frames?
If the glass is the correct size, the spacer bar should just behind the rebate.
Glass should not move side to side because plastic glazing shims should be positioned in the gap.
Is it upvc frames?
Yes uPVC frames, the glass went in from the inside, like I said looked like a good job and I was happy with it, but the glass does move side to side by 5 to 10mm on each panel.
Would you suggest getting in touch with the person and ask them to come take a look?
The glass shouldnt move.
It should have glazing shims that are used to pack the glass each side and hold it so it cant move.
Yes get them back, its not correct
So I asked the question about the glass moving and got the following response, just not sure what to do?
'Hi it's because the gaskets attached to the beads are old and have lost much of their flexibility. It won't effect the performance of the glass, if it's an issue I can pack the corners if you like?'
What would your thoughts be?
Thanks in advance for the advice.
