We have two radiators on the second floor of our two story flat and our Megaflo CL170 unvented cylinder is on the first (ground) floor. For the past few days, we haven't been getting hot water to these radiators, but we have a bathroom on this floor and the sink and shower have been getting hot water fine. Just for kicks, I turned the radiators off and back on again and somehow hot water started coming to them again. Unfortunately, the next day they stopped working. My wife said she's heard some light knocking sounds coming from them on occasion. None of the radiators or taps we have on the ground floor are having any issues receiving hot water.
The Megaflo cylinder pressure is at 0.5 bar which is low, from what I've seen online. Could that be the cause of the second floor radiators not working? If so, should I attempt to repressurize the cylinder or should I have someone that knows what they're doing handle it (clearly, I'm not experienced with all this)? I've seen a video at https://www.redrow.co.uk/tv/videos/howto/how-to-adjust-your-system-pressure on how to do it but since that's not for a Megaflo I wanted to check first. I think I've identified the valves that would need to be turned (in attached picture). I know the radiators have their own pressurized system, too, so I'm not sure if that needs to be bled or adjusted?
I'm not sure if this could be related but the tundish has been leaking very intermittently. We had the combination valve and TPR valve replaced early this year so I'm wondering if it could be a malfunction with that work. I tried replenishing the air gap in the cylinder by turning off the water to the cylinder, opening the lowest sink tap, and turning the TPR valve, but no water came out of the tundish and there were no gurgling sounds from the cylinder, so it seemed as though the air gap wasn't the issue. I'm mentioning the dripping tundish in case that could have some bearing on the upstairs radiators issue.
Thanks in advance for any help and for your time!
