Bar mixers / offset connectors / fastfix connectors
17 Apr 2015
Hi
Currently got 2 15mm pipes at 150 centres coming through the tiles. Looking at a few bar mixers, which come with those offset BSP connectors that are meant to go into a female threaded wall plate elbow type thing in the wall. Obviously I haven't got that option, so any idea if the fastfix/wallplate type connectors which are basically a compression fitting to the pipe and screwed to the wall, can generally be used with showers that come with the angled connectors? I can't see why not if it's the same BSP thread size, but I guess the covering shrouds need to be big enough to cover the back plate thingies?
